Cisco 3550 12G и Avaya P333T не пингуется(
Сообщение v2008 » 18 ноя 2011, 11:47
Помогие задружить два коммутатора.
топология такая:
3550 по гигабиту соединен с 333Т по оптике.
на 3550 настройки порта:
Switch#show interfaces gigabitEthernet 0/7 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: 2-252
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
на 333Т все проще.
оптический порт - поднят 802/1Q
выключена автоконфигурация. (только при этих условиях поднялся линк - но не пингуется ничего)
медные порты настроены каждый на свой влан.
P330-1(super)# show interface
   Interface Name     VLAN    IP address         Netmask
inband                251   192.168.1.7      255.255.255.0
ppp   disabled        251   0.0.0.0          0.0.0.0
P330-1(super)# show ip route
Destination        Gateway
0.0.0.0            192.168.1.1
P330-1(super)# show port
Port   Name            Status    Vlan Level  Neg     Dup. Spd. Type
 1/1   NO NAME         no link   1    0      disable full 100M 10/100Base-Tx
 1/2   NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/3   NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/4   NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/5   NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/6   NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/7   NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/8   NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/9   NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/10  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/11  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/12  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/13  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/14  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/15  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/16  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/17  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/18  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/19  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/20  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/21  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/22  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/23  NO NAME         no link   56   0      disable full 100M 10/100Base-Tx
 1/24  NO NAME         connected 251  0      disable full 100M 10/100Base-Tx
 1/51  NO NAME         connected 1    0      disable full 1G   1000Base-Lx GBIC
 1/52  NO NAME         no link   1    0      disable full 1G   GBIC not present
вопрос. Чего забыл прописать на циске? Как добиться прохождения пакетов с 333Т на 3550 ?
Заранее благодарю.
v2008
Re: Cisco 3550 12G и Avaya P333T не пингуется(
Сообщение Андрей » 18 ноя 2011, 20:24
Подозревая в native vlan все дело. т.к. у самого была аналогичная проблема.
На cisco смените native vlan и попробуйте. Думаю, что будет вам счастье.
Сообщение v2008 » 19 ноя 2011, 01:40
странность заключается в том что у меня такая связка уже работает!
а вот новая нет( хотя порты настроены идентично!
в чем подвох немогу понять(
v2008
Сообщение root » 21 ноя 2011, 07:43
v2008 писал(а):Cisco 3550 12G и Avaya P333T не пингуется(
не пингуется что ?
покажи на каталисте:
sh run int gi 0/7
а вообще лучше
sh run
меньше вопросов будет
v2008 писал(а): Чего забыл прописать на циске?
вот что ты точно забыл так это подробнее изложить задачу, т.к. мы ни разу не телепаты
v2008 писал(а):Как добиться прохождения пакетов с 333Т на 3550 ?
прохождения откуда и куда ?
с чего сделан вывод что они не ходят ?
не видно маков ?
где находится 192.168.1.1 ?
v2008 писал(а):на 333Т все проще.
какой номер порта ? какие у него настройки ?
З.Ы. Пожалуйста пользуйся тегом CODE, когда выкладываешь конфиги на форуме.
Сейчас этот форум просматривают: Google [Bot] и гости: 4
